Failed to allocate a configuration control block. The Control Block will not be created. If this operation was triggered by a MIB command then the MIB signal will be returned with a failure code. This may cause some configuration information to have to be resent.
Investigate the source of the failure. It is probably due to a resource shortage.
Error
%p1% failed to allocate control block type %p2% identifier %p3%.
| Name | Type |
| p1 | String |
| p2 | xInt32 |
| p3 | HexByteArray |
